Reporting Bug!!
Jordo
Reporting Bug!!
Post by Jordo »
When "ON-board Datalogging" is enabled, and set to certain conditions, and you have a laptop pluged in also to datalog.
If you do a pull, the smmanger will freak out.
To fix problem, "disable on-board datalogging"
s300
what version are you referring to?
jdmspecdc5
Post by jdmspecdc5 »
this would explain why sometimes the s300 bugs out and pretty soon im boosting 360psi @ 60,000rpm haha. thanks for the tip. hopefully it gets rid of this problem.
Jordo
Post by Jordo »
jdmspecdc5 wrote:this would explain why sometimes the s300 bugs out and pretty soon im boosting 360psi @ 60,000rpm haha. thanks for the tip. hopefully it gets rid of this problem.
Yes, it will fix the problem is you just disable it.
Spunkster wrote:what version are you referring to?
newest version.
s300
I cannot report problems without the exact version number found in Help, About.
Also it is best to have onboard datalogging disabled unless you are gogin to be at the track or the laptop is not accesible for datalogging.
Jordo
Post by Jordo »
its version 1.1.0.0 according to the about
s300
Try checking for updates. Version 1.1.1.0 is the most recent version.
