Page 1 of 2
06 Si support?
Posted: Sun Jan 08, 2006 1:49 pm
by xsydx
I havent seen any information on support for the 2006 civic si...
any info?
Posted: Mon Jan 09, 2006 10:31 am
The KPro will not work with the 06 Civic due to drive by wire.
Posted: Mon Jan 09, 2006 6:48 pm
by xsydx
will there be any other products hondata has planned or in development? Or will it go the way of the 05-6 rsx?
Posted: Mon Jan 16, 2006 1:20 am
by Scourge
Then is it possible to replace the throttle body with the RSX-S's and use the 02-04 RSX ECU without losing functionality? Also, what would the extent of wiring changes be in that scenario?
Posted: Mon Jan 16, 2006 10:52 am
Hondata is currently looking at the possibilities for the 06 SI. Due to the nature of development, we do not know what or when we will have for this application at this time.
Posted: Tue Jan 24, 2006 11:50 pm
by Zigg
Now if I am not mistaken, you now do offer the K-Pro for the Acura TSX, which is also a Throttle by Wire system. By bypassing that and using a normal throttle cable from an RSX, is it possible to "upgrade" to a K-Pro then?
If so... I own an 06. You can play with it.
Posted: Wed Jan 25, 2006 9:51 am
We only have a reflash for the TSX. Some race vehicles have re-pinned the wiring harness and swapped over to a manual throttle cable.
Thanks for the offer, but Hondata has an 06 Civic Si.
Posted: Wed Jan 25, 2006 11:26 am
by Zigg
Well, if you guys ever do get a reflash going for the Si, I would be highly interested in it.
I don't know if you guys have noticed the horrible flat spot in the powerband near 4,000rpm yet... it's kind of weird feeling. And of course, that car can easily rev past the 8,250 rev limiter... so whatever you deem suitable for that car has to be better than 8,250.
Well, I look forward to anything you guys come up with for that car.
SI 2006
Posted: Mon Mar 13, 2006 7:04 pm
by kevin bureau
Then, how u guys tuned the TOV 2006 civic si project car if the k-pro serie is not rdy for si 2006???
Re: SI 2006
Posted: Tue Mar 14, 2006 12:48 am
by Razathorn
kevin bureau wrote:Then, how u guys tuned the TOV 2006 civic si project car if the k-pro serie is not rdy for si 2006???
They probably wired a k-pro up to it 'race style' with custom wiring and with a cable TB -- similar to how they tuned the TSX motor so soon. That's my guess. There's a big difference between that and a finished product that is able to be sold to the general tuner public.
Posted: Wed Mar 15, 2006 4:56 pm
by Zigg
Even a reflash at these stages on the TOV Si is possible. It doesn't even have to be repinned and cabled "race style."
Hopefully this news and knowing they've cracked everything but fuel on the ECU is good news, and can show us that they can have a fully cracked ECU in the next 3 months, and a finished product in... a while.
Posted: Thu Mar 16, 2006 2:20 am
by Razathorn
Zigg wrote:Even a reflash at these stages on the TOV Si is possible. It doesn't even have to be repinned and cabled "race style."
Being a software engineer, let me just say that modifying 'maps in memory' is a whole order of magnitude easier than changing code and adding in features like those found on k-pro. Granted, I'm not an inside man at hondata, so I really don't know any details, but just in general, modifying values in a memory range is not nearly as difficult as the work it probably took to make k-pro happen. Not to discount what has already been done, just realize that it's very apples and oranges as far as level of effort goes in the general case.
Posted: Sat Mar 25, 2006 11:47 pm
by patriarch
I installed CAI in my 06 Si the other day and theres a nasty hesitation when i floor it at 3K.. I heard the Si Hondata was working with had AEM CAI and that you had encountered a similar problem. From what I understand it has to do with the MAF readings. If or when you come with something for the Si, will this issue be fixed? Is it something you are looking into?
Posted: Mon Mar 27, 2006 9:58 am
The AFM (air flow meter) needs a non-turbulent air flow, otherwise the calculated air mass fluctuates, especially at low flow rates. This is not something which the ECU can compensate for.
Posted: Tue Mar 28, 2006 12:45 pm
by Razathorn
Hondata wrote:The AFM (air flow meter) needs a non-turbulent air flow, otherwise the calculated air mass fluctuates, especially at low flow rates. This is not something which the ECU can compensate for.
Any idea why honda would incorperate a maf sensor now?
