quick question about s300?
o5mar1
Post by o5mar1 »
i have both a p06( single cam non-vtec) and a p75(ls ecu) i was wondering if i could install the s300 on the p06 and use the ls base map. Or would i have to install it on the p75 ecu for it to run correctly.
You can use any calibration on any (supported) ECU - P30, P73, P28, P30, P06 The only difference will be if the ECU has the circitry to support the knock sensor, secondary intake runners etc. In your case the LS base calibration will work on a P06 ECU - just disable VTEC.
o5mar1
Post by o5mar1 »
thanks for the quick response. well im runing a all motor ls setup and i dont plan on doing a ls/vtec anytime soon.
