Launch control w/ anti-lag
1320motoring
Post by 1320motoring »
just a question...........has anyone had any success with this feature? If so, what are some of the parameters used to make it work?[/b]
airshifter
Post by airshifter »
works a little bit on our car now without the msd ignition
but when I used the msd 2-step on top of the s300 antilag our b16 launched with 20psi @ 8500 with a t4/60-1
the M&W ignition doesn't have 2 step, we only get 6psi now
didn't add fuel and pulled 20 degrees of timing out 400 rpm before the msd 2-step activation point and had the s300 2-step 200 rpm past the msd 2step
1320motoring
so its more an ignition pull over adding fuel also? I read on an efi forum that adding fuel and also pulling ignition was what worked for the person. Only thing is.....he had a different type of engine management.
kaj
Post by kaj »
i can't get my launch control to work. either it's on..or it isn't. i tried to use my A/C button.. even inverted the input.. still nothing. it's either on or not. period, which makes warming up the tires in the water box impossible :(
kesnut
Post by kesnut »
any update on this?
the guy who are using it, what setting do you have and how did you go about getting the settings?
SpadeMotorsports
Post by SpadeMotorsports »
I use it and it works too good for me. I hit 24 lbs. of boost within 2 bumps of the launch limiter. I am having a problem with the limiter holding. If I set it for 7022, it will bounce from 7000 to 9500. Not good in terms of trying to control spin.
kesnut
Post by kesnut »
i played with it weekend, but i was not sure if it was really working? as the i made changes to the setting, boost was the same. that is why i was asking, how do you go about setting this up, what signs are you looking for,listening for.
thudreem
Post by thudreem »
SpadeMotorsports wrote:I use it and it works too good for me. I hit 24 lbs. of boost within 2 bumps of the launch limiter. I am having a problem with the limiter holding. If I set it for 7022, it will bounce from 7000 to 9500. Not good in terms of trying to control spin.
Wow, what setting are you using to achieve 24 lbs off the 2 step?
I bet if you look at your datalogs you will find that your wheel spin is casuign the mph to be above the cutoff for the launch control. Try raising the launch speed.
SpadeMotorsports
I bet if you look at your datalogs you will find that your wheel spin is casuign the mph to be above the cutoff for the launch control. Try raising the launch speed.[/quote]
There is no wheelspin, for I am not moving. I am sitting on the line pre-launch.
Can you post datalogs showing this?
siadam
Post by siadam »
The antilag is just a check box plus adjustments of fuel/timing to activate correct?
As for the launch control..is there an external wiring/etc that is involved to have it activated...?
Thanks.
8)
Built, NOT Bought.
^^clicky.for.more.info^^
