rom chip.
94zchatch
rom chip.
Post by 94zchatch »
When I have the interface box and all the nessesary cables hooked up to the ecu do i need to use the chip supplied to me from hondata or can I use one with a base map that I already have, and also if I can use it, how do I get it to work with boost?
Custimization is the key to Indivuality
Unless your dealer put a base map on the chip, the chip supplied with the Hondata system is blank. Is the other chip you have a Hondata chip? I would recommend contacting your local dealer and get hte car on the cyno to be properly tuned as soon as you can.
94zchatch
Post by 94zchatch »
I just purchased the hondata and The problem i have is that the chip that I got with the hondata is a p72 but the ecu that I have is a p75.well the chip that I already had in my p75 is not a hondata chip but I have been using it in my ecu for about a year. Its a chip that is burned with the spoon program but its not spoon. I dont want to have to buy a p72 ecu just to use my hondata I would like to use my p75 and just reburn the spoon chip If possible.
you boght the HOndata to be able to fully tune it but hten say you want to be able to use some copy of a untuned program....this makes no snese.
Take the car to a Hondata dealer and get it peroprly tuned on the dyno and you will have a well running safe running car.
94zchatch
Post by 94zchatch »
The spoon chip is tuned to my car without turbo. I bought the Hondata to tune my car with the turbo. The chip I received with the Hondata was wrong. Can I use the chip that I already have with the Hondata by changing to read boost.
Can I tune my spoon chip, that was origanaly tuned for all motor, with the hondata to run boost?
No you can't use the "spoon" chip.
