Software Version
macer
Software Version
Post by macer »
Will my Dyno tuned map upload with any version of K-PRO software, in other words each time I up-date the software will it effect my main map if I need to upload it again?
You should always be using the most recent version of software.
Razathorn
Post by Razathorn »
What I do is open my map with the new kmanager and re-save it as a new name (like -something). Then I upload the new calibration. If things work right, I use that map from then on. I generally keep the old one around just in case. That's just common computer sense in my opinion.
macer
Post by macer »
Razathorn wrote:What I do is open my map with the new kmanager and re-save it as a new name (like -something). Then I upload the new calibration. If things work right, I use that map from then on. I generally keep the old one around just in case. That's just common computer sense in my opinion.
Yep have made a few copies just in case.
