Greddy turbo w/ KPRO questions
petah
Post by petah »
Hi there,
Kinda new here. Have 2 questions:
1. k20a2-rsx-440cc16ohm-greddy-cal: I heard Greddy is suppose to switch to 12ohm injectors? If they did would it be okay to use this basemap or is there something else I should be using?
2. k20a2-rsx-440cc16ohm-greddy-cal: is this partially tuned with FMIC or without FMIC?
Thanks.
Peter
additiaonal fuel tuning would be needed with the 12 ohm injectors. It was setup using a FMIC.
petah
Post by petah »
any idea if fuel adjustment is minor between 12 & 16ohm injectors?
i guess to run without FMIC for a while with the base cal i'll have to pull out some ignition out (maybe this cold weather would be okay).. i'll see how my install goes and go from there.
thanks for your help.
There is significant difference between the 12 and 16 ohm injectors at part throttle. Measure the injector resistance. The last calibration was with the intercooler.
