Is a S300 compatible with a P08 ecu?
guilotine
Post by guilotine »
Were tuning a built B-series motors with some Toda ITB's...
Can we use a USDM P08 ECU from a VX with the new S300 system?
is there a special p08 I need to look for to be compatible with the S300?
Is there any negatives from using a P08 instead of a P28?
thanks-Gil
To my knowledge there is no rectangualr case P08. All P08's are JDM and square cases.
guilotine
Post by guilotine »
Spunkster wrote:To my knowledge there is no rectangualr case P08. All P08's are JDM and square cases.
so is a OBD1 VX ecu compatible with a S300 yes or no?
I believe the VX uses a P07 and it is not compatible with Hondata. Post a picture of the inside of the ecu.
RMS
Post by RMS »
there are two different po7s
one uses a five wire o2
the other (cali model) is identical to a p28 though it may be missing the power steering input.
if you have the correct one (4-wire o2) then yes it is compatable.
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
