S300 & JDM P30
mammad78
S300 & JDM P30
Post by mammad78 »
can i use my jdm p30 ecu with s300, if only the shape is the problem i can modifie it, cuase this is for a drag use only. i just want to know if the s300 supports jdm p30 board
thanx
RMS
Post by RMS »
others have made it work, but i think you will lose some functionality so far as generic outputs are concerned.
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
mammad78
Post by mammad78 »
RMS wrote:you will lose some functionality so far as generic outputs are concerned.
thanx for your reply
what do you mean by that?
mammad78
Post by mammad78 »
RMS wrote:others have made it work.
how? is it the same steps that is mentioned in the hondata site
Dee
Post by Dee »
Did you ask this question Honda-Tech?
The case itself is the problem. You will need to do some hacking on the case to get it to work with a JDM P30. Your best option is trade the JDM P30 for a USDM P30. Joe at locash racing hooked me up with a USDM P72 since I could not use my JDM P72.
Mura
Yes, we've made it
Post by Mura »
you can make something like podium with few sockets. It's looks like podium using on S200 with Romulator. You should insert 2 male sockets to the upper level of this podium.
Also you should solder 4-pin socket by wires.
Sure, you could not to close the cover of ECU after this installation, but I think it would not a big problem for drag car )))
No dreams, just POWER.
