Knock sensor bypass???
mikiebabie
i just installed a 93 sohc vtec motor into a 91 si hatch and i'm using pre obd b16a computer and the car works fine but i'm not running the knock sensor so i was wondering if anyone knows how to bypass that or what the normal running resistence is of the knock sensor any help would be great thanks
91 si
2nd gen zc
zc tranny
zc ecu
2nd gen zc
zc tranny
zc ecu
Carchitect
You probably need to get your 91 si ecu redone thru zdyne. As much as I don't like their product. Zdyne seems to be able to play with the OBD0 ecus a lot more than hondata. However, I would recommend you change the vehicle over to OBD-1 instead. However, it won't be very economical the vehicle will be happier and drive better on OBD-1 than OBD-0
Joe
Joe
Experience is what you get when you don't get what you want
08 IS350 Sport Package, Levinson, Nav, Radar cruise.
94 JZA80 6speed undergoing major weight reduction AKA 911 GT2 killer.
90 DA9 B18C5 retired auto-Xer
