Erratic Idle
jsimon9633
Erratic Idle
Post by jsimon9633 »
what are possible causes for an erratic idle?
here are my symptoms
vacuum reading is fine its about -14lbs
but the idle goes from 1000-2000 rpm
and the AF all over the place of course
the ignition goes from 0-6 values
I dont have any vacuum leaks
i checked the IAC valve and it seemed ok
what possible things could cause this or is it just tuning?
Ravenous Si
Post by Ravenous Si »
Try cleaning the IAC valve.Or adjust the slider in the idle tab of Kpro.
jsimon9633
Ok I think I found the problem
car is idling in columns 6-7
it should be 1-3 no?
does this mean its a vacuum leak for sure?
That is a vacuum leak.
Ok - once the posts get abusive I have to moderate them, so your last two posts have been deleted. Also consider that the best way to get us to help you is not to post 'fuck hondata' on public forums. While we're sorry to hear that your ECU was damaged, it is out of our control and we cannot replace every ECU that has been damaged in a customers car. There is nothing in the KPro which can electrically damaged the ECU, even if something went wrong with the KPro. We would like to keep working towards a solution for you, but it up to you.
Ravenous Si
you cant even post your answer on the right persons forum I think this Hondata post is to me not this guys post!!
I replied to that abuse that you posted here. Banned. The choice was yours.
sohfast94
Post by sohfast94 »
How about a solution to this guys problem? I've tried three different 3bar MAP sensors to no avail. They all check out with a voltmeter with the key on but, once you go to start up the vehicle it goes to 0.5psi columnand of course the idle is very erratic
Your guess is as good as mine
The problem was sorted out - the injector driver IC in the ECU was damaged from either the injector or injector wiring.
