Having a problem with K-pro!
Posted: Sun Nov 13, 2005 1:51 pm
I have a eg swapped with a k20a3 motor with k-pro. The other day a friend loaded a base model rsx calibration in but i have loaded the 2002 civic si since then. I now have numerous error codes 20-2 p1298 eld circuit high voltage and 65-2 p0141 secondary 02 circuit heater circuit malfunction. It was all working fine before. Also should i leave the multiplexer enabled? It is currently unchecked and if i do check it i get an error for manifold forgot the exact code. Also whats the proper steps in loading the calibration when changing settings on each calibration? Thanks in advance for the help!
