nitrous control output problem
Posted: Tue Nov 08, 2005 7:58 pm
by airshifter
shouldn't the output activate if I zero RPM, TPS, VSS conditions when trying to use it toactivate a boost controller
the only time I can get the output to do anything is when I invert the polarity it goes to groun
nothing else seems to change what it is doing
doing same thing on both nitrous control outputs whether the engine is running is key just on
I need this boost controller to work for this weekend
Posted: Wed Nov 09, 2005 10:29 am
Can you post the calibration you are using and post a datalog showing it not working with that calibration?
Posted: Wed Nov 09, 2005 11:58 pm
by airshifter
from what I noticed on the datalog between N1 and N2 u can't use 0 rpm, or 0 tps, 0 vss maybe because u aren't above 0 but at 0 to activate
N2 never activated with min rpm set at 0, that was the only difference in activating between the two
don't know how N1 got to 3000 min turn on it just keeps doing that on its own every now and then
would have had more datalogs but #3 sleeve sank .010" on that pull in our Darton sleeved block, will have it apart and redecked by friday hopefully so we can run this weekend
Posted: Mon Nov 14, 2005 11:23 pm
by airshifter
it seems to work while going down the track
ran 9.86@146 this weekend
