v10
Posted: Sun Oct 30, 2005 7:01 pm
Hondata Masked Man, Can you explain the application for the tps ignition retard and give pros and cons? Thanks
The amount of ignition retard from throttle tip in can be adjusted by gear. A value of -100% is minimum retard; a value of 0 of higher is more ignition retard.
