Please help. UK Civic type r with PRB with wideband
Posted: Sat Oct 29, 2005 9:23 am
by wheelyking
I have had installed a US Kpro on my uk civic type r around 3 months ago. Around 300 miles ago i replaced the narrowband sensor with a wideband OEM, but neglected to alter the wiring as i had no diagram, everything was ok until around 2 hours ago when the strangest thing started to happen.
The car now has a strange idle which drops to 1000m rpm, then shoots up to 3000 rpm continously, whether driving or on idle.
This is very worrying as i am going drag racing tomorrow.
The car has a CPL built engine with dropped compression and a Jackson running 12psi crank wheels. Also running 80 shot of nitrous.
I have checked for errors on k manager but nothing comes up. The car still drives fine above 3000rpm with no strange noises. The only thing i can think off is that maybe the ecu has just clicked that a wideband has been fitted, and maybe the erratic idle is a safety feature inherant of the ECU to let the engineers know there is something wrong with the 02 sensor.
Your thoughts would be appreciated.
Either way i still need a Wiring diagram, if you have 1.
thanks
Alex
Posted: Sat Oct 29, 2005 11:33 am
by wheelyking
Having replugged the UK ECU back in to confirm whether or not it detects the wideband sensor, error Code 41 DTC PO135 has flashed up.
Is this expected with a wideband and PRA Ecu?
:x
Al
Posted: Mon Oct 31, 2005 9:54 am
by vtec9
I have 2002 euro civic type-r
I bought this ($1595 - K-Pro with new Honda PRB ECU based off US RSX-S) for my car I have stock sensor and my engine check light is always on it says error code 41 I can't solve the problem
Posted: Mon Nov 07, 2005 12:33 pm
We do not have the wiring diagrams, but you can contact CPL and he should be able to help you diagnose the issue and properly wire everything. I fyou did not rewire everything and ran the incorrect sensor, you may have either damaged the sensor or ecu.
Posted: Sun Nov 27, 2005 1:27 pm
by vtec9
who is CPL??
Posted: Mon Nov 28, 2005 10:56 am
CPL Racing is in our dealer list for the UK.
