what to use on my sol with P06
DrakSol
Post by DrakSol »
i have a 94 del sol s model, i did a min-me swap to add v-tec. i am also running a 50 and somthimes 75 shot of nitrous. i want to be able to plug my laptop in when the car is running and program it in real time. what should i buy and what options should i get? i dont need nitrous options because it is a cutom dry kit and i have a fields sfc v-tec and fuel controller to controll fuel boost. so should i get the v-tec option anyways just to be able to controll it better or just get ridd of the sfc?
Carchitect
Post by Carchitect »
Min-me?! You mean to say you are controlling your nitrous thru the vtec solenoid?
This could be tough here. I'm not so sure as to what you want to do here.
The only way I can see of any kind of advantage here is that you can get rid of the fuel solenoid and run direct port nitrous. Run a lot larger injectors and when the vtec kicks is the injectors will introduce more fuel. As far as tuning the wideband to work with nitrous, I'm really not so sure as to how well it will work.
My suggestion is to not run nitrous and save up for the boost instead. But to each one is his own.
Joe.
Experience is what you get when you don't get what you want
08 IS350 Sport Package, Levinson, Nav, Radar cruise.
94 JZA80 6speed undergoing major weight reduction AKA 911 GT2 killer.
90 DA9 B18C5 retired auto-Xer
