my hondata s200 is weird need help
Posted: Mon Sep 26, 2005 8:06 pm
by eggy
my hondata works perfect when the chek engine blinks if it stays on car boggs and wont pull for shit why? and also besides that when i give it full throtle car boggs and all it does is back fire why?
Posted: Tue Sep 27, 2005 9:22 am
Is the light on the interface box flashign or solid? More details are needed. Has the car been tuned? Are there any error codes?
Posted: Tue Sep 27, 2005 10:32 am
by eggy
well at first the light on the s200 blinks and the turn on and stay on after a while i dont no the chech engine blink once slow after a while but its weird i turned it on and it worked perfect but i stoped sum where and left the key forward for about 5 mins and then i turned it on and it just boggs its tuned for a sohc turbo!!!
Posted: Tue Sep 27, 2005 11:46 am
Was it tuned on your engine, or are you runinning someone elses tuned chip.
When it is boggin is the check engine light on? Is the interface box flashing when you are experiencing problems?
Also please do not use run-on sentances as it makes trying to determine what you are describing very difficult.
Posted: Wed Sep 28, 2005 8:15 pm
by eggy
yea it was tuned for my motor. when the check engine stays on it wont go past 2000 rpms. then when the check engine blinks my s200 box blinks exactly the same way. i dont understan it was working perfect, when i left my fan running it did what its doing write now
Posted: Thu Sep 29, 2005 6:22 am
If you have a 2000 rpm rev limit then check the boost cut settings.
