K20Z QUESTOIN..
Posted: Mon Sep 26, 2005 6:15 pm
by NIKO
SO BASICALLY... WILL HONDATA MAKE KPRO FOR THE K20Z1?? OR IS IT STUCK TO JUST A REFLASH...
IS THE REFLASH GOOD?? WHAT DOES IT REDLINE AND WHEN DOES VTEC KICK IN?
Re: K20Z QUESTOIN..
Posted: Mon Sep 26, 2005 10:18 pm
by Razathorn
NIKO wrote:SO BASICALLY... WILL HONDATA MAKE KPRO FOR THE K20Z1?? OR IS IT STUCK TO JUST A REFLASH...
Judging from your other posts, there will be no reflash that suits your needs correctly. If you had an rsx -- perhaps if and when 05 flashes came about, you would be okay... but don't even think about reflashes in my opinion if you're working on a swap with different variables like fuel pump, manifods (intake or exhaust).
I think your best, and perhaps only, bet is an 02-04 used rsx ecu modified with the kpro system, primary o2 sensor, and getting the 05+ rsx adapter harness. I say 02-04 rsx ecu because you want one that will drive the reverse lockout on the 6 speed transmission. Using the 6 speed transmission without the reverse lockout signal from the ecu is not fun in the least.
