Engine cut during shifting.
chunky
Post by chunky »
I'm not sure if this is doable, but would it be possible to wire up the two clutch pedal sensors to the ECU to cut engine power allowing a full throttle shift with minimal transmission stress?
there is a clutch switch that tells the car when the clutch pedal is initially pressed (used to turn off cruise control) and a clutch switch that tells the car when the clutch is fully depressed (used to enable starting of car). Are those switches wired into the ECU?
It would be nice to have the ignition cut when the first switch is off and then restored when the second switch is off.
Is this possible within the ecu? I assume not since the two clutch switches are not listed among the availible sensors.
You can take me out of the race, but you can't take the race out of me.
Razathorn
Post by Razathorn »
There is a sensor. It is part of the cruise control system from what I remember seeing in the shop manual.
chunky
Post by chunky »
Razathorn wrote:There is a sensor. It is part of the cruise control system from what I remember seeing in the shop manual.
I mentioned the sensors in my post already. I'm just wondering if they're visible to the ECU. If not, i'll just have to rig something that uses one of the 3 input pins for the sequential shift feature.
Razathorn
Post by Razathorn »
Doh -- it's monday ;)
