Basic help question.
Posted: Wed Sep 21, 2005 8:46 pm
by maxjap
Ok, Im new to this K-Pro stuff so here it goes, I just received my K-Pro today and loaded the K-Manager like I was supposed to, followed the directions to the letter, so needless to say everything loaded just fine. I plugged the usb cable in, then plug the harness in the ecu and it doesnt even reconize the ecu being plugged in. BTW, its a K20a2 in a 2002 Civic Coupe. I did move the ground from the intake to the head and did the necessary wiring re-pinning and hardwired the primary O2 in so IDK whats left. Is it a driver problem? Or am I just stoopid and can't figure this out???? Anyways whatever you guys can help with would be greatly appreaciated.
Thanks,
Jayson
Posted: Wed Sep 21, 2005 10:05 pm
by maxjap
Oh yea I almost forgot, at one point it did say ignition on and it started to jump back and forth from on to off like almost every second. Also this laptop doesnt have online access right now so I dont know how to clear the security if I had too.
Thanks,
Jayson
Posted: Thu Sep 22, 2005 9:59 am
this sounds like a wiring problem in the car. Be very careful...you may damage the ecu, K-Pro or both. Check grounds, main relay wiring as well as proper pinouts. I cannot help with specifics, as we do not do engine work or engine swaps.
Posted: Thu Sep 22, 2005 12:07 pm
by maxjap
Ok, thanks for the info I will recheck all the wiring and the pinouts again.
Thanks,
Jayson
