Hondata and inspection question
atropos
Post by atropos »
I've been trying to get a solid answer on this:
The car: 2001 prelude
The intended mods:
intake
full exhaust system w/ headers
cams / slight headwork (later on)
First off, which Hondata would make the most sense for this setup?
Secondly, will the Hondata still allow the car to pass NY state inspection? Obviously all the smog sensors etc will remain on the car.
Thanks in advance!
Which Hondata you choose is entirely up to you. You can use the s100, s200 or s300 dependingon what option you want and if you plan to tune yourself.
As for emissions, it will not pass an OBD2 scan as you are using an OBD1 ecu with a HOndata system.
RMS
Post by RMS »
but a proper tune will pass tail pipe testing, if not the visual inspection.
RaVer Motorsports (559) 733-4711
ravermotorsports@earthlink.net
atropos
Post by atropos »
Well thats the issue.. they don't do taipipe tests here, just the OBD-2 hookup, which I imagine would fail instantly. It seems like there are few if any reasonable options for newer cars.
RMS
Post by RMS »
better save a stock ecu, cat, and injectors just for testing purposes.
