P28 ECU question help!
snatchback
Post by snatchback »
I have a b18c1 in my 92 hatch and i just got a p28 for it today but its throwing the check engien code 19 which has something to do with an automatic transmision. So my question is why would it throw that code, did i get the wrong ecu, is there a diference between and automatic p28 and a manual? ALso it redlines at like 7600 and i thought t would redline higher. So im thinking i have an automatic p28 does anyone know anything about that cause i couldn't find any info on the net. Please help!
marlborocars
Post by marlborocars »
You can convert the ecu from AT to MT
snatchback
how do i do that, and i how do i tell if i even have a automatic or manual ecu?
marlborocars
If you have a resistor in RP17 and RP18 is AT to convert remove RP17 and place a jumper on RP18.
snatchback
what tools will i need to do that? I dont wanna mess up the ecu you know, is it hard to do? And once you change it over, what exactly is the difference?
