Help with K-Pro Nitrous Install
Hey whats up I connected my nitrous to the kpro like it says with the relay connected to a 12v switched fuse, under the steering wheel fuse box. When I test out the n20 it doesnt spray, I feel the fuel change, but I dont feel the n2o working. Ive ran a wet kit before i got my kpro and it worked fine and I felt a hell of a difference, but now its not working, I connected the purge button to only work when i switched the power for the n2o on and I noticed that when I have the switch powered off, and I hit the brakes im able to purge the n2o but when i let go off it i cant purge it until i turn the switch on. I connected it to e22 at first which is the brake one if im not wrong, so i changed it when I noticed the brake thing with the purge button. So I changed the arming input to e16 and it still doesnt work and the system does the same thing with the purge when i hit the brake. when i did my test runs it didnt work at all. Please help me out in letting me know whats wrong, any help would be apreciated. Thanks a lot for the help in advance. I have on 02 RSX Type S, with dcrh, greddy evo, aem cai, type r cams & intake manifold, Hondata intake manifold gasket and Kpro.
