Fresh Install Without CD
PixelStyles
Post by PixelStyles »
Hey all, I just formated my Laptop, and I don't have my CD.. so I downloaded the software online. Everything installs fine, I updated the USB drivers fine as well. So now I have an issue when trying to connect the ECU to the laptop, when installing the ECU drivers it asks for FTD2XXUN.exe and well... I don't have it. Any work around?
Tell windows to look in the KManager installation directory.
PixelStyles
Thanks for the reply, I tried what you reccomended, but the file was not located there. I did a search on my whole system, and no such file exists.
1. Uninstall the USB drivers (if you can) from the Control Panel.
2. From KManager, select 'Update USB Drivers' from the Help menu.
3. Plug in the KPro. It should ask you for a path to the files, enter c:\program files\kmanager
If it doesn't work after than then try running #2 with the KPro plugged in.
Also, what does Windows identify the KPro as - 'Hondata K-Series ECU' or 'FTDI Serial Device'?
