Pinging at light loads (cruising)
Posted: Thu Aug 11, 2005 8:11 pm
by Hoggy
Hi,
Datalog shows pinging at light loads (below 45kpa) mainly below 3.5k rpm. It is not audible and usually happens when holding throttle position. No pinging if car is accelerating. Should I detune ignition or ignore it?
Thanks.
Posted: Fri Aug 12, 2005 9:20 am
Try removing some timing in that area and see if it goes away.
Posted: Fri Aug 19, 2005 9:06 am
by Hoggy
Spunkster wrote:Try removing some timing in that area and see if it goes away.
No, it doesn't. Tried dropping 5 degrees and it's still happened. This is after installing crower cams. The ignition maps used were tuned for the stock JDM cams. I was informed couple of local cars with the same cams have the same outcome, and caused by the valve trains.
Posted: Sat Aug 20, 2005 12:57 am
by Razathorn
Hoggy wrote:Spunkster wrote:Try removing some timing in that area and see if it goes away.
datalog?
Perhaps it's mechanical noise the knock sensor is picking up?
Posted: Sat Aug 20, 2005 10:27 am
by tryfe
The Crower & IPS-K2 cams cause valvetrain noise that seems to light up the CEL with false knocks under low rpms. Just make sure you have no knock up top and don't worry about it.
Posted: Sat Aug 20, 2005 11:46 am
I've dynoed many IPS-K2 and IPS-ME cams and never seen any 'false knock'. Also I've done a few Crowers.
Check the valve clearances - some people were measuring between the cam and follower. The feeler should be a sliding fit.
Posted: Sat Aug 20, 2005 3:12 pm
by tryfe
Hondata wrote:I've dynoed many IPS-K2 and IPS-ME cams and never seen any 'false knock'. Also I've done a few Crowers.
Interesting..
Posted: Sat Sep 03, 2005 10:42 am
by RSX-CT
I can only imagine how loose that must leave the valve clearances.
Posted: Sun Sep 11, 2005 7:00 am
by thesilverbullet
is the pinging mostly in 5th and 6th. if so try taking timing out by gear. what's your timing values in this area?
