Does compression ratio affect base tunes?
Does the compression ratio affect base calibrations? If it does, what would be necessary to change to make the base tune work. Example: 8.5:1 using a revhard55010psi base tune.
Yes, lower compression is a direct influence on the response to the base calibration. Not to say you could'nt start with that basemap in your example, in fact I think you would be safer if anything. I imagine your timing would be off intially, but I dont know 100%
hope this helps,
Evan
hope this helps,
Evan
modified EP3 cn kit/K24a1/K-Pro
