Noob w/ 2 Days K-pro Experience- Solid Check engine Light...
Posted: Fri Aug 05, 2005 11:59 am
by phenomenal_rsx
I installed K-pro two days ago, The current setting I upload makes the car scream and I am stoked at the power gain, however I have a solid check engine light. There are no error messages and as far as I can tell everything is fine. The first setting I uploaded made the engine run rough, but I had no check engine light. Can any of you offer up and suggestions to solve this?
Posted: Fri Aug 05, 2005 2:51 pm
What is the error code?
thanks for the reply. I have no idea
Posted: Sat Aug 06, 2005 1:23 pm
by phenomenal_rsx
The software is not giving me any error messsages, when have it set to data log. The light blinks once when i turn the car on. Is that an error code? Maybe you can help a total noob. Where do i look up error codes even if I knew that what the error code was?
Is it standard protocol to re key the car to the ECU, and could that be the issue at hand? just throwing that out there... thanks
Posted: Mon Aug 08, 2005 9:35 am
What light on your dash is on?
check engine light
Posted: Mon Aug 08, 2005 1:50 pm
by phenomenal_rsx
The check engine light is on solid, it falshes once when I start the car. Also the flashing green key is on I presume because I need to have the car rekeyed.
Posted: Mon Aug 08, 2005 4:46 pm
will the car rev over 4000 rpm?
yes
Posted: Sat Aug 13, 2005 3:49 am
by phenomenal_rsx
Yes the engine the runs like its tuned perfectly. It revs freely above 4000 rpm. Should I be getting error codes while in data log, and do error codes trigger the check engine light? Do you know of any solutions to my dilema, or know anyone that I can speak with? I am planning further modifications, and I want to have everything dialed in.
D
Posted: Mon Aug 15, 2005 9:20 am
You need to datalog and while doing it check the error codes.
