fuel values and tps vs map
Posted: Fri Jul 29, 2005 4:37 pm
This may be a bit of a non kmanager specific questions and more of a general EFI question in some regards. What are the values in the fuel table? I've heard of these called 'fuel units'. In something like a split second controller, you have duty ms for secondary injectors for instance. Are the values time or a volume thing?
Also, how are these values related to how much fuel is actually delivered per put. If you have the throttle plate wide open, it's a different world than say 40% open... but the map could still be in the same area.. over 80kpa -- but 40% throttle is quite a bit less air. I guess I'm curious as to how it would not be running way rich under light acceleration that made it to columns 8+ if throttle plate isn't wide open. Any insight into how this is actually working would be great.
Wayne
Wayne
