What base program to use?
Mr Plow
Post by Mr Plow »
A2 block with A2 internals (forged crank, wiseco pistons(9:1), eagle rods) and A3 head with a cybernation turbo kit and 550cc rc eng injectors. This is in an 04 civic si using kpro.
Razathorn
Post by Razathorn »
Why didn't you get an a2 head... it breathes beter than the a3. Just curious.
Mr Plow
Post by Mr Plow »
Thats for the future. Got the a2 block because my a3 was thrashed. My a3 head was fine. I dont plan to get the a2 head till i can get the 6spd at the same time.
Razathorn
Post by Razathorn »
Mr Plow wrote:Thats for the future. Got the a2 block because my a3 was thrashed. My a3 head was fine. I dont plan to get the a2 head till i can get the 6spd at the same time.
Another thing... isn't the k20a2 block the same as the k20a and k20a3... hence the k20... the difference being the rods and pistons? Since you built that up I don't know how much if it is actually an "a2's block" anymore ;) ... it's just a nice built up k20 block IMHO. A2 head would be the icing on the cake.. hope you find one cheap.
mdoyle
Post by mdoyle »
A3 is missing oil squirters, different crank, oil pump, water pump and oil pan.
But yeah, both are 2 liter K series blocks.
Razathorn
Post by Razathorn »
Oil squirters? .. I Thought that was in the head... do you mean it's a channel in the block?
mdoyle
Post by mdoyle »
Razathorn wrote: Oil squirters? .. I Thought that was in the head... do you mean it's a channel in the block?
I mean there are lines in the block that squirt oil onto the pistons to keep them cooled off for high RPM use.
Mr Plow
Post by Mr Plow »
Yup the A2 block has the squirters.
WPB EP3
Post by WPB EP3 »
How did your A3 get thrashed?
Mr Plow
Post by Mr Plow »
Sorry I meant trashed. I needed to replace the #4 cylinder sleeve because the ringlands shattered on the piston so the piston wasnt going up and down normal but up/down on an angle. I have gouges in that sleeve.
WPB EP3
Post by WPB EP3 »
Mr Plow wrote:Sorry I meant trashed. I needed to replace the #4 cylinder sleeve because the ringlands shattered on the piston so the piston wasnt going up and down normal but up/down on an angle. I have gouges in that sleeve.
Ouch, how did this happen? Any reason behind the catastrophic damage?
btw, I think you would just use the 550cc for 10psi map as a starting point and tune from there, but Im not 100% positive.
Evan
02SilverSiHB
Post by 02SilverSiHB »
Evan
it was because he was using guardian! hahahaha, just messing with ya
07 Si Sedan
WPB EP3
Post by WPB EP3 »
LOL!
Im tired of not having a custom tune bro, lol.
I could make a list about tired of not having:
-staged boost
-custom tune
-ability to custom tune cam angle
-rev launch
Im gonna have to do something about this.
