I think my A/C has been disabled completely!
Posted: Mon Jan 13, 2003 6:08 pm
by see2k
Hi,
back in the day, before I had the Hondata, my A/C used to work with OBD II ecu's and the piggy backs. But now, my A/C won't work anymore.
I just idle, and nothing happens. By any chance is my A/C not working because of my P28 ECU/Hondata 4b?
When I check the romeditor, in gray, it says to disable ac at 5500 rpm
or 50% throttle and turn it back on at 6% or below throttle.. It is not user changeable.. so I am wondering if this is a bug or not?
I am going to put the OBD II ecu back on and see what happens tonight.. more on this tonight! :?
Posted: Fri Jan 17, 2003 7:06 pm
by Jaker
It could be that your OBD conversion adapter is not correctly configured to retain your A/C functionality.
Posted: Mon Jan 27, 2003 11:08 am
by see2k
Jaker wrote:It could be that your OBD conversion adapter is not correctly configured to retain your A/C functionality.
yes you were correct. i found a unconnected ODB connection, and put in back in its right place by looking at another wiring harness.
it works now..
by see2k
it works now..
