I built a Honda Accord IS -96 with obd1 ecu as illustrated in link below:
http://jynssi.hohto.net/projektit/honda/index.htm
More pics in http://jynssi.hohto.net/temp/
We used haltech F9 to provide fuel for boost, and used a reversed one-way valve in t-piece for stock MAP-sensor hose to prevent it to sense the boost.
A couple of probs:
-a engine fail signal light lids immetiately after starting
-Otherwise works fine but gags under hard acceleration between 3000 and 4000 rpm's
What happens when the engine gags? I doesn't detonate, or run lean/rich... How can I change the ignition advance in these revs?
At the present the owner runs on 1bar boost, appr. 250whp.
Accord turbo gagging between 3000 and 4000 rpm?
image is nothing, boost is everything
