Alright my question is will I be able to some how use the s200 in this setup and if so what do I need to do to use it. I know that the b18b from the integra is a ODB0 but I was wondering if there is anything I can do.
I'm using a B18A1 from a 91 Integra LS in my 92 Civic...very similar setup.
You can use the S200, but will need to convert to OBD-1. I recommend retaining your Del Sol's engine wiring harness and using it on the LS engine. You'll need a 94+ Integra LS distributor.
