Weird immobilizer problem
Posted: Fri Jul 08, 2005 12:19 pm
by mdoyle
I first got K Pro 6 months ago on my stock PNF ECU. The car ran perfect, I was able to leave the immobilizer on with no problems.
I later put a K20A2 cylinder head on my A3 block, ran the K20A2 CAI kal with the immobilizer on, still no problems.
This past week I swapped in a K20A, uploaded the K20A2 ITR Cams JRRH 310cc kal and it wouldn't start. I turned off the immobilizer and now it starts and runs fine.
All three different engines used the same ECU, both times before I was able to leave the immobilizer on, now that I have K20A I have to turn it off, any ideas?
Re: Weird immobilizer problem
Posted: Sat Jul 09, 2005 9:24 pm
by hnx676
As far as I know, K20A does not have any immobilizer at the first place...
mdoyle wrote:I first got K Pro 6 months ago on my stock PNF ECU. The car ran perfect, I was able to leave the immobilizer on with no problems.
Posted: Sun Jul 10, 2005 2:22 am
by mdoyle
hnx676 wrote:As far as I know, K20A does not have any immobilizer at the first place...
The K20A ECU doesn't have an immobilizer, but my car does. I also used my stock wiring harness.
Posted: Mon Jul 11, 2005 10:22 am
Try clearing security and uploading a new calibration.
Posted: Mon Jul 11, 2005 10:25 am
by mdoyle
My kal has already seen the dyno, and a lot of road tuning, should I just clear the security then upload that, or try a different kal altogether?
Posted: Mon Jul 11, 2005 12:26 pm
by mdoyle
Spunkster wrote:Try clearing security and uploading a new calibration.
Didn't work.
Posted: Fri Jul 15, 2005 10:09 am
by mdoyle
b-u-m-p
Posted: Fri Jul 15, 2005 2:49 pm
The K20A ECU does not support an immobilizer, so the immobilizer must be disabled in the calibration.
Posted: Fri Jul 15, 2005 11:27 pm
by mdoyle
Hondata wrote:The K20A ECU does not support an immobilizer, so the immobilizer must be disabled in the calibration.
I'm running the K20A2 JRRH 310cc calibration though.
Another local EP3 owner is having the same problem as me, only he is running the stock K24A2 calibration.
Posted: Mon Jul 18, 2005 9:49 am
What is the code from the side of your ecu?
Posted: Mon Jul 18, 2005 12:11 pm
by mdoyle
I'm not sure, i'll have to go out and check.
If it's PNF A12 or A13 though, that update didn't fix my problem.
