question..
urbanracer1
question..
I have a obd1 b18b...I'm putting it in my 96 obd2 hatch. My question is will the obd1-obd2 adapter work/plug in if i use my stock DX ecu and stock DX wiring harness? Is my motor going to run properly?
The OBD-I/OBD-II adapter is what allows you to plug your OBD-I B18B ECU into your DX wiring harness, so you can swap in the B18B. You don't need your stock DX ECU after that.
-Andy
-Andy
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
