Problem upgrading KManager
rco1
Post by rco1 »
I have been using V1.0.15.0 for quite a while. (mosty for datalogging) Yesterday I upgraded to the latest version 1.2.0.2. The new version will not work correctly, It senses things like ignition on/off and coolant temp but will not display RPM, VSS, MAP and many others. I re-installed ver 1.0.15.0 and everything works again. Is there a flash upgrade or firmware change that needs to happen the allow me to use the newer software? My KPro is over a year old now.
Any help would be appreciated.
Did you upload your calibration using the new version?
rco1
Post by rco1 »
I did upload my calibration with v 1.2.0.2 and it looks wrong. However when I look at the calibration I uploaded using v 1.2.0.2 with v1.0.15.0 it looks fine. further more downloading the calibration I just uploade totally screws up the car. If I take the same calibration and download it using v 1.0.15.0 it restors the car to perfect woking order.
Do not download the calibration from the ECU. Always load the calibration from disk.
If the calibration doesn't work when you upload it with V1.2.0.2, post it here and we will look at it.
