k-pro,greddy,idle bog help
Posted: Sat Jun 04, 2005 10:22 am
by k-rooki
hi, I just installed the greddy turbo kit for my '02 US RSX_S. it started fine, warmed up, no leaks. (phew!) it idles normally for a while and them will bog down pretty bad. if I rev it, when it comes off of rev it will go below target idle and bog down bad, the higher I rev it the harder it falls and at around 5k if i just let off the gas it will stall. though it restarts fine. I should add that it doesn't jump or rev higher, just bog.
thanks for your reply, Greg
Posted: Mon Jun 06, 2005 9:13 am
What injectors are you using, and which calibration did you use?
Are you using stock spark plugs?
Posted: Mon Jun 06, 2005 9:37 am
by k-rooki
440 CC. loaded standard greddy map
also getting an 1166 cel.
denso iridium stock heat
Posted: Tue Jun 07, 2005 8:31 am
1. Uninstall KManager. 2. Download KManager from here 3. Install KManager using the file you downloaded. 4. From File->New select the 440cc Greddy calibration. 5. Upload.
If you still have any problems then make a datalog and post it here.
Posted: Tue Jun 07, 2005 7:09 pm
by k-rooki
I already have the update you refered to.
Posted: Wed Jun 08, 2005 6:42 am
by 02SilverSiHB
k-rooki wrote:I already have the update you refered to.
did you try what he said though? maybe there was something wrong when you updated...deleting the file and downloading it again may help.
Posted: Wed Jun 08, 2005 6:44 am
by 02SilverSiHB
doh, your a/f sensor is messing up...might be it. I just noticed you said you had the cel for that=Air Fuel Ratio (A/F) Sensor (Sensor 1) Heater Circuit Malfunction
Posted: Sat Jun 11, 2005 10:58 am
by k-rooki
thanks everyone for your help, it was just the idle control. I just bumped it a little and it's fine now.
