k-pro,greddy,idle bog help
k-rooki
Post by k-rooki »
hi, I just installed the greddy turbo kit for my '02 US RSX_S. it started fine, warmed up, no leaks. (phew!) it idles normally for a while and them will bog down pretty bad. if I rev it, when it comes off of rev it will go below target idle and bog down bad, the higher I rev it the harder it falls and at around 5k if i just let off the gas it will stall. though it restarts fine. I should add that it doesn't jump or rev higher, just bog.
thanks for your reply, Greg
What injectors are you using, and which calibration did you use?
Are you using stock spark plugs?
k-rooki
Post by k-rooki »
440 CC. loaded standard greddy map
also getting an 1166 cel.
denso iridium stock heat
1. Uninstall KManager. 2. Download KManager from here 3. Install KManager using the file you downloaded. 4. From File->New select the 440cc Greddy calibration. 5. Upload.
If you still have any problems then make a datalog and post it here.
k-rooki
Post by k-rooki »
I already have the update you refered to.
02SilverSiHB
Post by 02SilverSiHB »
k-rooki wrote:I already have the update you refered to.
did you try what he said though? maybe there was something wrong when you updated...deleting the file and downloading it again may help.
07 Si Sedan
02SilverSiHB
doh, your a/f sensor is messing up...might be it. I just noticed you said you had the cel for that=Air Fuel Ratio (A/F) Sensor (Sensor 1) Heater Circuit Malfunction
07 Si Sedan
k-rooki
Post by k-rooki »
thanks everyone for your help, it was just the idle control. I just bumped it a little and it's fine now.
