RomEditor 3.0.12 bug, maybe
Doodoo
Post by Doodoo »
I downloaded 3.0.12 Romeditor and I have been having connection isses since then. I reloaded 3.0.11 and the connection was established immediately. Thoughts please. Thanks.
JT
Post by JT »
What type of connection problem do you have? I have noticed the RomEditor will not see the pocket programmer/emulator if I simply launch RomEditor and download the ROM. I have to go to Settings screen and click OK and exit before it will see it... even the correct settings are already in place.
Doodoo
Post by Doodoo »
It would not connect at all. I tried re-booting, then starting the car, then connecting the serial cord. Also when it did manage to connect once the software was waaaaaaaay behind when refreshing. I did not mess with any refresh rates at all. The datalogging was in slow motion.
I reloaded 3.0.11 and it connected just fine the first try.
Thanks.
see2k
Post by see2k »
i've noticed that ever since i upgraded i haven't been able to datalog without a lot of problems.
I get an error message from Hondalogger reporting my unit doesn't have datalogging capabilities, I hit OK, and all of a sudden Im datalogging.
the rom editor won't even datalog so I m not sure if its the PC or my s200.
I attend college at U-Si-R... Wanna start a club there?
210whp 155 wtq S200@5.5psi@7200 rpm
230whp 177 wtq S200@~9psi@7200 rpm
rebuilt engine 9:5.1 compression
271whp 236wtq S200@14.5psi@7200 rpm
1/4 Unknown
Connection problems
If you have RomEditor make sure you upgrade your ROMs by using the 'File->Convert ROM Version' function.
