base map work
dornon13
base map work
Post by dornon13 »
well i currently have a tuned map up to 8psi...i am planning to turn up the boost but i am wondering if and how much i should richen the extra few cells for my new pressure. Does hondata create rich boost cells when it creates boost tables or should you go back and increase fuel through the boost cells before making runs?
DaX
Post by DaX »
You should only be using your basemap as a starting point if you are a tuner or to drive your car to a tuner if you aren't tuning yourself.
You shouldn't be guessing...you should be using a wideband to determine how the cells need adjusting.
dornon13
Post by dornon13 »
i am tuning my self i am asking because you have to start somewhere..i guess ill rephrase...should i go to romeditor ..create boost tables...then just make a pass like that or should i richen the boost cells after i have "created boost cells/columns"? i realize i need a wideband which is why i have one, i just dont want to go kaboon from detonation the very first run.
