Jumper J12
JoeJoe1
Jumper J12
Post by JoeJoe1 »
I received my ECU socketed from Hondata and jumper J12 does not appear to be cut, what is the purpose of cutting it? and would it work fine if it is not cut? because I read that it's just a suggestion. Thanks.
JoeJoe1
Post by JoeJoe1 »
Anybody?
EGHATCH
Post by EGHATCH »
its ok if its uncut. i didn't cut mine...datalogging works fine. thought i think its recommended.
you wont learn until you actually do it.
turbo_civic_si
Post by turbo_civic_si »
it lets the ecu know whether it is communicating half duplex or full duplex. when j12 is cut it switches into full duplex and allows faster communications.
JoeJoe1
Post by JoeJoe1 »
Oh ok, thanks for the info guys. I'll just go ahead and cut it then.
ak94gsr
Post by ak94gsr »
what do u mean about faster communications?? between the labtop and ecu???
so cutting it does no harm?cause mine is not cut either
EGHATCH
Post by EGHATCH »
will try it later...
i guess to doesnt have a downside when cutting j12.
it means you will be datalogging if FD. transmit and receive can be done simultaneously
CivicVTi
Post by CivicVTi »
The downside is that you cannot connect to the Honda dealers' diagnostic center with the connector under the dash. Communication is faster and you can record at a faster rate.
turbo_civic_si
faster communications between the ecu and the hondata box, etc...
half-duplex = cb radio, one person at a time can talk.
full-duplex = telephone, cell phone, etc. both can talk at the same time.
DaX
Post by DaX »
Holy hell, is this actually technical talk on the Hondata forum? :lol: Great info guys!
Twitch
Post by Twitch »
Can anybody confirm that after cutting the j12 Hondata still worked fine :?:
Never Buy ANYTHING from
RICKY CALDWELL a.k.a Silverbeast/HoustonSI
turbo_civic_si
i confirm it still works fine. mine is cut and has been cut on all the ecus i've soldered for hondata.
Twitch
Post by Twitch »
turbo_civic_si wrote:i confirm it still works fine. mine is cut and has been cut on all the ecus i've soldered for hondata.
Thanks :D
