I just finished installing a p28 and the s200b... bump the key to the run position and I get a slow flashing red light.
ok so I double and tripple check everything... my dealer burns me a new basemap to be sure and check the ecu over for continuity.
everything looks good and I put it back in... flashing red light, but as I move the box the light gets irradic or sometimes goes out completely. so I fiddle with the cable for a minute and if I hold in the interface cable just right the light goes solid.
so thinking the pins on the box's connector or the cable's are not making proper contact? anyone have any comments or have this issue?
going to try telling the dealer tomm. and see if he will let me try another box/ cable.
opinions welcome.
interface cable or box problem?
Re: interface cable or box problem?
How did you make out with this?twkdcd595 wrote:I just finished installing a p28 and the s200b... bump the key to the run position and I get a slow flashing red light.
opinions welcome.
I am in the middle of installing a rev-hard kit on my buddys 97 SH and i have the same problem....the S200 shows a slow flashing light...turns out the chip we thought had a base map on it is either blank or the wrong map from the dealer!!
