Full throttle shifting...
Paisan
Post by Paisan »
I was wondering about how the shift limiter is supposed to work. My friend says to set it at 6500 RPM so when I shift at redline, the RPMs don't drop below 6500 RPM. Is this true, or do I need to set it higher so it doesn't bounce off the rev limiter?
But she was a niiiiiiiiice! High five!!
96 Honda Civic DX Hatchback w/ B18C5 swap
Hondata S200
DaX
Post by DaX »
By using full throttle shift, you will be 'bouncing off the rev limiter' during shifts, but you'll be doing it at a designated RPM [say, 6500]. This is how Hondata keeps your revs up. Why are you afraid of a rev limiter?
Paisan
Post by Paisan »
So setting the shift limiter at 6500 will keep the revs from dropping below 6500, correct?
Hondata S200
DaX
Post by DaX »
Paisan wrote:So setting the shift limiter at 6500 will keep the revs from dropping below 6500, correct?
As long as you keep the throttle at WOT. full throttle shift sets a temporary rev limiter.
