MSD SCI and Hondata S200
Posted: Wed May 18, 2005 2:46 am
by pcguy760
Hi,
I would like to know if I can use my MSD SCI or some other electronic ignition booster with a Hondata S200 setup?
Let me know - thanks!
Posted: Wed May 18, 2005 6:12 am
by DaX
Yep. I'm using the MSD 6A with a trigger adapter circuit and external coil so that I got rid of the stock Honda coil and ignitor. It runs fine in conjunction with my Hondata.
Posted: Fri May 20, 2005 11:50 am
by pcguy760
What I do not understand is, if I am gonna run a turbo - how will the Hondata be able to retard the timing, etc. if the MSD is controlling the spark and ignition?
Thanks.
Posted: Fri May 20, 2005 12:29 pm
by DaX
pcguy760 wrote:What I do not understand is, if I am gonna run a turbo - how will the Hondata be able to retard the timing, etc. if the MSD is controlling the spark and ignition?
Thanks.
You do not need to get an MSD unit that can retard timing or anything like that if you plan on using Hondata. If you do get an MSD unit capable of timing control, you should set the MSD unit to a 'like stock' setting and let Hondata control all the timing. The MSD unit should only be used to create a more powerful spark.
I'm using an MSD 6A [one of their most basic units] to take advantage of the capacitive discharge, more powerful external coil, and so that I can run my ignition without the OEM ignitor module [I'm using a DIY trigger circuit that I built]. Eliminating the stock coil and ignitor greatly strengthens the automobile's ignition system, as these are generally the weak points in the system.
