Problem maybe k-pro
DecoyDC5
Problem maybe k-pro
Post by DecoyDC5 »
I wanted to share this with you to see what kind of feedback I get.
http://forums.clubrsx.com/showthread.php?t=255602
This is not somethign that would be caused by the ecu. For the car to stay on, the ecu is still receiving power, which means that there is a fault somewhere in your wiring or ignition switch. I would suggest taking your car the the Acura dealer for diagnostics. Since you have had aftermarket components installed in the car this is most likely the source of the problem.
DecoyDC5
Post by DecoyDC5 »
Thanks. I have to catch the car when it's acting up so the dealer can see something is wrong.
