using three step
EGHATCH
using three step
Post by EGHATCH »
is there a way i can disable the full throttle shift and just make use of the launch control?
you wont learn until you actually do it.
shinociv
Post by shinociv »
just set your full throttle shift to an rpm that is higher than your rev limit.
EGHATCH
Post by EGHATCH »
but the full throttle shift can only be set to 5t-8t right? it says on the manual..im changing gears at 9-9.5t :(
shinociv
Post by shinociv »
I have mine set to about 10,500 and my rev limit is 8800
EGHATCH
Post by EGHATCH »
great. i'll try it tomorrow..
i was planning to do that but the manual said that it can only be set from a certain rpm like 8000 or something....so i didn't try it..
Paisan
Post by Paisan »
What is your setup? I ask this because I'm wondering about the same thing for the full throttle shifting.
But she was a niiiiiiiiice! High five!!
96 Honda Civic DX Hatchback w/ B18C5 swap
Hondata S200
EGHATCH
Post by EGHATCH »
b16a with LS crank. 185whp/130ft-lb.
with s200.
