Hondata Log - Knock Sensor
Posted: Wed May 04, 2005 3:52 pm
I recently purchased a Hondata S200 system with a dyno tune on my EG B18C. Today was the first chance to take it to the track. I went 1 Sec. slower than I had gone last Sept. Below is the HondaLogger file of that run. It seems that the Ignition Knock retard while idling is .25? (Lambda 0.60). When running down the track, the Ignition Knock retard is going from 4? to 6? (Lambda 0.60 to 0.61).
http://home.comcast.net/~ExiledinIN/Forum/15_738.rec
Assuming that the tune was done correctly, what would cause the .25? Ignition Knock Retard as well as the 4? to 6? during full throttle? Also, should there be more fluctuations in the Lambda value? If so, is this a sign of a bad O2 sensor?
I would appreciate if someone can help as it is frustrating me right now.
