kpro with greddy kit question
Posted: Wed Apr 27, 2005 7:51 pm
by weltall
okay i have the greddy kit on a civic si
test pipe
odb2 and the o2 heater boxes disabled
ran a datalog and while at 8 psi and wot
lambda(A/F?) is reading a solid 11 ish/1
car runs fine and all is there something to worry about?
or does that sound about right?
no cels or dtc's either
occasionally spikes to 10psi yes the restrictor is removed and i have the i/c
also im running the greddy cal *untuned*
Posted: Sun May 08, 2005 11:27 pm
by ares650
If I remenber right, I think the stock O2 will read as low as 11.4a/f. You can try to lean the car out till about 11.6, the car will be happy. That way you can check that O2 reading.
Posted: Tue May 10, 2005 7:23 pm
by weltall
is there another place i can look to see if the primary is working right?
like in the sensors area?
i dont wanna lean it out and then i blow my car up
it does however during crusing move around to around 14 13
bounces around while im driving in traffic
so i do think it is okay
Posted: Tue May 17, 2005 11:54 am
by krystar
the sensor maxes out at 11.48
u could be running 9.0 AF's and you wouldn't know it.
highly suggest you remove 10% fuel and redatalog. optimal power is made around 12.5 anyway.
