boost leak.
rev hard guys
boost leak.
Post by rev hard guys »
i really think that i'm close to be ready for dyno tuning!!! :D here is my set up: civic si, stock k20a3 with hondata heatshield gasket,k-pro, rev hard turbo kit, manuel boost controler set to 9.5 psi on the gauge inside the car, walbro intank fuel pump(255 lph), stock fuel rail, 550 cc rc injectors, fuel return line, fpr set at 55 pounds of pressure in rail under boost, act extreme organic clutch... thats it i think!!! MY PROBLEM...when i go full throtle the boost never hold 9.5 psi it always drop to 7-7.5 around and continue to drop slowly to 5.5 psi exept on the last gears(5) it hold corectly 9.5 psi and drop to around 8.5 at 6500 rpm.
can somebody can please tell my why it hold the boost ok on the last gear and not on the 1-2-3 and 4 gear??? :? i check all the piping connection and everything is ok. so now i realy need to fix that before the final tuning so please help!!! thank you in advance
civic sir 2004 (canada), with rev hard turbo stage 1. 550 cc rc injectors, heatshield gasket, act extreme organic clutch, exhaust vibrant, 2.5'' cat back, 2.5'' test pipe, tein coilover and thats it i think!!!
