P28, S200 with DTC 19 and 41
Posted: Mon Apr 25, 2005 5:24 pm
by srcracing
How can I have a DTC code 19 with a stick shift? Can I run open loop and bypass DTC 41?
Posted: Mon Apr 25, 2005 5:47 pm
by DaX
Your ECU is probably set up as an automatic, which can easily be remedied by moving a jumper on the PCB.
You can disable the o2 heater in Hondata, eliminating the code 41.
removing auto
Posted: Mon Apr 25, 2005 6:00 pm
by srcracing
Do you know what jumper I nedd to remove or add to make it a stick ECU? I disabled O2 in closed loop tab, but DTC 41 still comes up, any idea?
resolved DTC 19
Posted: Mon Apr 25, 2005 7:41 pm
by srcracing
I guess if I read the manual and could remember all of it, I could have solved it myself. Anyway, thanks for the help. Removed RP17 and RP18 and installed a jumper in RP18. That fixed DTC 19... But I still have a DTC41 with the O2 disablied in the closed loop tab. Am I still missing something? Also, check engine is on (obviously) and the LED on the S200 is slowly blinking. Check the troubleshooting page, and all seems correct, any ideas?
