S200 install on 96 integra GSR
Posted: Thu Apr 21, 2005 11:52 am
by misterdude
on the applications chart for the S200 it lists the P72 ECU - The 96 integra GSR has P72 ECU can it be socketed and used with the chip or is it different? the 96 is OBD2 so do I need a P72 from a 94 or 95 GSR?
or are they the same? its confusing when the number is the same.
will the JDM ECU's work on a US car same as a US ECU?
Posted: Thu Apr 21, 2005 12:15 pm
by DaX
You will need an OBD-1 ECU. Some ECU's [the P75 for example] came in OBD-1 and OBD-2 cars. The OBD-2 ECU's cannot be used with Hondata.
Posted: Fri Apr 22, 2005 1:01 am
by RMS
the jdm unit is your best bet since the iabs have the correct polarity for usdm obdII cars.
JDM ECU
Posted: Fri Apr 22, 2005 10:21 am
by misterdude
RMS wrote:the jdm unit is your best bet since the iabs have the correct polarity for usdm obdII cars.
which one would you recommend using?
best JDM ECU?
Posted: Fri Apr 22, 2005 2:37 pm
by misterdude
it looks like the best JDM ECU to use would be the P72J because it has VTEC IAB and KNOCK ?? AM I CORRECT?
Posted: Fri Apr 22, 2005 11:49 pm
by RMS
all the obdI jdm p72 have those, but avoid the automatic at all cost.
To RMS
Posted: Sun Apr 24, 2005 10:28 am
by misterdude
If I send you a virgin US P28 can you make it work with the IAB VTEC KNOCK and be hondata compatable? or better yet just tell me what I need to do to get it all working right, cus I can socket it and I will need to add my OBD2 to OBD1 conversion board anyway.
my other P28 took a crap and it was converted by hondata.
I hate that bad Idle crap that it has when its cold thats cus the IAB polarity is wrong or not even working right?
Posted: Sun Apr 24, 2005 11:32 am
by RMS
adding knock requires a knock board... unless you have a spare board your best bet is to start with a p30/72 ecu.
adding iab is easy for us though. iab does not effect idle stability in any instance i've seen. and the p28 already has vtec.
give us a call this week and we can set you up.
new ECU
Posted: Sun Apr 24, 2005 11:29 pm
by misterdude
I think im gonna try to find a P72
